Forum: Old versions
Topic: VDJ 7 and Akai MPD18
I have version 7 of VDJ and an MPD 18 that I want to use along with it to trigger samples/effects. I've searched the internet to find a way to use the two together and found nothing basically. I've searched through the config window a bunch of times but couldn't find anything relating to recognizing my MPD18. I was wondering if anyone had any knowledge or help they could share on which route I should take to get these two working together.
geposted Fri 19 Aug 11 @ 12:51 am
You will need to upgrade to the full VirtualDJ Professional to use other MIDI controllers alongside your MixTrack Pro.
Your MixTrack Pro VirtualDJ LE entitles you to a considerable discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/
MPD18 is not natively supported by VirtualDJ, but you should be able to map it via Simple MIDI Wrapper - Please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html for basic mapping instructions.
For best results, a proper definition and mapper will need to be created so that button LED's work, etc. - Please see https://virtualdj.com/wiki/ControllerDefinitionMIDI.html
The following tool may help: https://virtualdj.com/addons/12994/VDJ_MIDI_Controll_Definer.html (You will need to register your Pro serial number to access this.)
