Hi djs, i use virtual dj quite a bit. However, i need to transfer some of my music on to cds because i have started djing in a club a few times a month. but they just have a standard cdj set up. whats the best way to organise my cds?
geposted Fri 19 Aug 11 @ 12:05 pm
"What's the best way to organize my CDs"? Is this a trick question, or are you just having a bad day? The best way to organize your CDs, is which ever way will work best for you. We don't know your style, or what type of club it is. What's best for me, will probably not work for you. I would not even think about using CDs anymore. That's why I use VDJ, so I don't have to bring CDs. I would find a way to incorporate my VDJ into their system. It may take more setup time, but I would find a way to use VDJ, or I would not work there.
geposted Fri 19 Aug 11 @ 12:25 pm
hey calvinator, i've had to use cdj sometimes but mostly use vdj at gigs. if you want to burn a playlist made in vdj to cd the best way I've found is to use Winamp Pro. I've tried using windows media player and unfortunately it can't load a vdj playlist so Winamp Pro is the way to go. Good luck.
geposted Fri 19 Aug 11 @ 12:47 pm
