What is the best place to get Karaoke Music.
I bought Party Tyme karaoke from best buy.
Does not show the words or anything.
I only get Karaoke from the net search feature.
Can't seem to find anything that work with Virtual Dj.
Please help guys....
geposted Fri 19 Aug 11 @ 3:49 pm
acekaraoke.com
Great source for all karaoke labels...
DJ RuDe
DJ RuDe
geposted Fri 19 Aug 11 @ 4:59 pm
If you really want to get into doing karaoke the music isn't cheap. A friend of mine has spent thousands buying directly from Sound Choice and Chart Buster, and that will only get you a partial library.
Allot of Sound Choice are now discontinued, which sucks cause they are the best. Chart Buster can send you monthly discs to keep you up-to-date with a subscription I believe.
The real work is then copying the discs to mp3+g and onto a external hard drive and maintaining a up-to-date library.
As far as making books, theres software for that.... whole process takes allot of time and effort, but if you enjoy doing karaoke its worth it.
I'm sure more people will offer some advice on this, so...
Good luck!
Good luck!
geposted Fri 19 Aug 11 @ 5:00 pm
I did a series of videos on my Youtube channel regarding karaoke and how to rip the discs and use the files with Virtual DJ, etc.
http://www.youtube.com/rudedog66
look through the videos to find the ones regarding karaoke...
DJ RuDe
DJ RuDe
geposted Fri 19 Aug 11 @ 5:11 pm
All of these are good, Try it....
http://www.chartbusterkaraoke.com/
http://www.soundchoicestore.com/
http://www.acekaraoke.com/
http://pophitsmonthly.com/
Good Luck,
Joey.....
Good Luck,
Joey.....
geposted Fri 19 Aug 11 @ 6:58 pm
I'm with bojett on this one. Tricerasoft is a no b.s, simple to use source that I sometimes even used while on an actual karaoke gig.
geposted Sat 20 Aug 11 @ 1:07 am
hello im from argentine south america. I m fan of Gordon lightfoot, in tis place is not easy to getthe originals albums of Gordon but i have a lot of this. I need the karaoke version of "If you need me" and "Its worth bealivin" If anybody have .this versions i be thankful to send me, Thanks and sorry but may bad escriture. Good bay.
geposted Wed 23 Nov 11 @ 6:01 am
Nobody will send it to you because this is illegal.
Illegal sharing of copyright material is not permitted on the VirtualDJ forums.
DO NOT request this ever again on our forums or your account will be locked.
If you need these songs, please search legitimate karaoke sites and purchase it. Some links to popular services can be found above.
geposted Wed 23 Nov 11 @ 9:29 am
