I have a Numark DJ IO and am using it with a Hercules 4MX, but I can't seem to get them set up the way that I want. I have one output plugged into output 1, another output plugged into output 2, and then my headphones plugged into the headphone port. The outputs work fine, the only problem is that when I try to cue the next song, it starts playing through the speaker output, which obviously isn't supposed to happen, so I was wondering if anybody could tell me how to set this up so that I can cue my next song without hearing it through the output? Please help asap!
geposted Fri 19 Aug 11 @ 5:35 pm
The 4-Mx has its own built-in sound card - You should be using this, not an external card, which is not supported in VirtualDJ LE.
Please see http://www.virtualdj.com/wiki/4-Mx.html for the correct settings.
geposted Fri 19 Aug 11 @ 7:39 pm
