Hi, I'm thinking of buying Virtual DJ Pro Full and I want to be able to broadcast video as well as audio. Is this possible? I've found some information on how to broadcast audio, but I'm not sure if you can broadcast video as well. Do I need to buy any special software or hardware to do this?
Any help will be much appreciated!
Thanks
Tim
Thanks
Tim
geposted Sat 20 Aug 11 @ 11:17 am
Yes you can try Ustream.
Good Luck
Huey
Good Luck
Huey
geposted Sat 20 Aug 11 @ 11:27 am
Hey, could you give me a bit more detail on how to do this? I've tried using adobe flash media live encoder and ustream, and I can get the audio to stream, but can't figure out how to get the video to stream as well... Is there a better program to use? Any advice much appreciated!
Thanks
Tim
Thanks
Tim
geposted Sun 28 Aug 11 @ 12:11 pm
And btw, I'm currently on a trial of the full version of virtual dj, and have the Denon MC6000.
geposted Sun 28 Aug 11 @ 12:12 pm
Ok, so I've fixed the video problem (using Screen Camera), so I can now broadcast video from virtual DJ using abode flash media live encoder.
But I have two more problems...
- I can't get the audio to come through adobe flash media live encoder (I thought it was working before, but it was actually the sound being picked up by my webcam)
- I can't figure out how to have the audio coming through my computer as well as being able to listen to music on my headphones that are connected to my Denon MC6000.
Any bright ideas?!
Any bright ideas?!
geposted Sun 28 Aug 11 @ 2:40 pm
geposted Mon 29 Aug 11 @ 11:34 am
