I was doing VDJ with videos working fine without an extended screen. I then later installed a projector and couldn't get VDJ to find the video card to do the extended screen so I shut it down and restarted. From then on VDJ would not find the music video files or karaoke files in the folders. All it found was folders and they were empty. Windows media play saw them, I saw them on the hard drive. Another dj program saw them but not VDJ. I tried everything except ejecting the hard drive because it was being used by another program. VDJ never found the files at all throughout the night.
geposted Sat 20 Aug 11 @ 10:52 pm
Did you check to see if any of these were checked or unchecked??
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 20 Aug 11 @ 11:11 pm
Hummm, the only thing that comes up is "show covers" and "show prelisten" nothing under that. Neither with double click, left click or right click.
geposted Sat 20 Aug 11 @ 11:27 pm
Am i the only one having this problem?
geposted Mon 22 Aug 11 @ 7:28 am
Hey Mike, give me a buzz on skype, see if two heads are better than one...
geposted Mon 22 Aug 11 @ 7:32 am
I had this too recently but can't remember how I solved it. Sorry
geposted Mon 22 Aug 11 @ 10:40 am
You have globally disabled the video engine....
Go to config -> VIDEO -> ....(to enable it again)
geposted Mon 22 Aug 11 @ 11:36 am
Thank you, that worked. I'll remember that in the future. It never used to be that way. VDJ saw all the files and if we loaded a video into a deck it automatically turned on the video. I'm so glad that is all it was.
geposted Thu 25 Aug 11 @ 7:54 am
If you untick video in CONFIG -> Video then it disables the video engine altogether, including the ability to load video files (So they no-longer appear in the browser.)
When video is enabled, normally the video output is not activated until you actually load a video (Or forcefully activate the video output via CONFIG -> Video or the default mapping CTRL+V), so you may be thinking of that.
geposted Thu 25 Aug 11 @ 11:05 am
Great, like i said, it made my day. Thanks again!!
geposted Thu 25 Aug 11 @ 8:32 pm
