Error in the sound driver (DirectX/wdm) your sound car is probably not connected or the settings r incorrect
I get this error when i open it what can i do ?
geposted Sun 21 Aug 11 @ 8:24 am
Check your sound card settings, make sure its hooked up right.
Huey
Huey
geposted Sun 21 Aug 11 @ 10:09 am
Try reconnected the dedicated hardware/sound-card w/VDj open then go in setting and set it to your CP sound card before you unhook your hardware/sound-card.
geposted Sun 21 Aug 11 @ 3:39 pm
try this click config , then sound setup tab , then
inputs none
outputs single output
soundcard (Your laptop) soundcard
inputs none
geposted Sun 21 Aug 11 @ 5:22 pm
just check in vdj sound set up for correct selection of the model of your sound card or else check your device manger in sound drivers if your sound card drivers are being installed properly, un install it and plug your sound card again to install its driver...i experience like this kind of problem hope it will help.. God Bless
geposted Mon 22 Aug 11 @ 4:47 am
i get this message if ive not connected my usb soundcard for my headphones. before i open vdj, you have a setting wrong somewhere. any chance of a screen print?
geposted Mon 22 Aug 11 @ 7:03 am
