I Recently Bought The VMS4 && I Can't Figure Out How To Record My Mix With It.!
I Went To CONFIG @The Top Of Virtual DJ Pro 7 & Went To Outputs And Put Advanced Config.
Then Put : Deck 1 - ADJ ASIO (ASIO) - Output 1&2
Deck 2 - ADJ ASIO (ASIO) - Output 3&4
Record Loopback - ADJ ASIO (ASIO) - Output 1&2
Then I Tried Recording My Mix && Still Doesn't Work.! Please Help.!!
geposted Sun 21 Aug 11 @ 11:54 pm
VMS4 has a real audio mixer in the middle, and therefor you need to follow this way .. https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html in order to record properly (including the mics)
The above setup should have inputs 1,2 for RecordLoopback instead of outputs, but it wont properly even with that change. Please read the above link.
geposted Tue 23 Aug 11 @ 7:49 am
what if your computer does not have a line in? can you use a 2nd sound card? I have a behringer UCA222....can I use this as my line in? although I have the VMS4 connected also?
geposted Wed 24 Aug 11 @ 1:08 pm
