Hi Everyone,
I am using the default VDJ skin.
What would be the string to map the 'loop in' button for the following modification:
When I press the 'loop in' button (either playing or paused), I want it to start playing a loop from the last set or used cue point, using whatever length the loop is set for.
Example: I am paused at cue 2 with the loop set for 8 beats. When I press 'loop in', play will start from cue point 2 and keep looping for 8 beats until I press 'loop out'. If the track is already playing, then the loop should just re-trigger.
Holding down the 'loop in' button for 1 second should toggle between the above mod and normal loop button operation.
Thanks in advance,
ClayDJ
Thanks in advance,
ClayDJ
geposted Mon 22 Aug 11 @ 7:26 pm
Not sure if it will work on a skin because of the holding command, but that's how I would script it, you need to change # for the correct deck and paste it into the xml file.
holding 1000ms ? toggle 'loopin' : var 'loopin' 1 ? deck # pause ? deck # goto_cue & deck # loop & deck # play : deck # goto_cue & deck # loop : deck # loop_in
time to buy Pro...
time to buy Pro...
geposted Tue 23 Aug 11 @ 10:17 am
synthet1c wrote :
time to buy Pro...
1++
geposted Tue 23 Aug 11 @ 2:03 pm
