i need help with my setup please it was all running fine until the other day when i switched it all on and for some reason its all messed up i run the numarks through the hercules which is my main mixer and for some reason when i load a track onto deck one it will the load the same track onto both decks even if i choose a seperate track for each deck i tried pressing eject on one deck which worked the other day but doesnt seem to work now i have also tried switching the usb ports but makes no difference help please :)
geposted Wed 24 Aug 11 @ 9:48 am
Go into options, then go to the mapper options. Click on the little box in the middle and there should be an option in there to select which ICDX to which deck. Can’t say any more than as I am doing this off memory.
Hope that helps though.
geposted Wed 24 Aug 11 @ 10:12 am
thank you your a star :) all up and running now for some reason vdj set the decks to default instead of decks one and two
geposted Wed 24 Aug 11 @ 11:11 am
No probs mate
geposted Wed 24 Aug 11 @ 11:13 am
