Forum: Old versions
Topic: PFL help
Hello,
I have a macbook pro and numark i/o...i finally figured out how to configure them with my headphones and amplifier. I would like to use both PFL's at the same time in my headphones, but the basic vdj7 skin only allows me to to toggle one pfl on and off at a time... is there a way around this??
geposted Sat 27 Aug 11 @ 4:23 pm
You will need to use a v7 skin (Such as the default 4 deck skin) that has pfl toggles instead of selection buttons.
Or you can map 4 keys on your keyboard to the following actions:
deck 1 pfl
deck 2 pfl
deck 3 pfl
deck 4 pfl
See https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
NOTE: Skins designed for VirtualDJ v6 or earlier do not have separate PFL capability.
