i am having problems with swicthing between 4 deck, with two time code. i was using one timecode coz one player was in shop and i had it setup in single mode and was switching between all four decks with no problem using the tab button. Now that i got my other player back and set it up with four decks, i can get the sound out of all the channels i have set but swicthing between the decks is a problem.
I would like the left timecode/player to control decks 1 & 3 and the right timecode/player to control 2 & 4 decks
i can get them to toggle through the decks but sometimes they won't stop the deck and i keep toggling threw then finnaly it will control it.
I have
2 pioneer 1000
pioneer 800 mixer
Asus G51J
VDJ 7.04
Thx for the help
I have
2 pioneer 1000
pioneer 800 mixer
Asus G51J
VDJ 7.04
Thx for the help
geposted Sun 28 Aug 11 @ 10:41 pm
This should help,
deck 1 timecode_active on ? deck 1 timecode_active off & deck 3 timecode_active on & deck 3 rightdeck & deck 3 select : deck 3 timecode_active on ? deck 3 timecode_active off & deck 1 timecode_active on & deck 1 rightdeck & deck 1 select
deck 2 timecode_active on ? deck 2 timecode_active off & deck 4 timecode_active on & deck 4 rightdeck & deck 4 select : deck 4 timecode_active on ? deck 4 timecode_active off & deck 2 timecode_active on & deck 2 rightdeck & deck 2 select
Enjoy
Huey
Enjoy
Huey
geposted Sun 28 Aug 11 @ 11:21 pm
Thx Huey
But i'm kinda new to script, so would this be two buttons i setup or one script using tab as the toggle? also is "?" part of the script?
geposted Mon 29 Aug 11 @ 8:29 am
Yeah I'm sorry should of typed that aswell, use 2 buttons. One with the deck 1&3 script and the other with 2&4.
Give me a shout if you need anything else
Huey
Huey
geposted Mon 29 Aug 11 @ 9:08 am
The first script for swapping decks 1 and 3 timecodes should have leftdeck instead of rightdeck
geposted Tue 30 Aug 11 @ 1:09 pm
Thx too both of you! Strange DJdad i didn't pickup on that but it seem to still work but i will change it.
geposted Wed 31 Aug 11 @ 9:14 am
how do you make it toggle PFL too along with toggling timecodes? i have my CUE SEL BTN togglin PFL now, what do i add to that script to toggle timecodes also?
geposted Fri 21 Oct 11 @ 9:42 pm
