Anybody having the issue where samples seem to play lower than tracks even though they are at max volume? Ive tried using various audio editing software to increase the volume in the samples but i get distortion when i get to a good volume level... obviously that distortion comes through when played in vdj...
Is there any way to increase the samples gain when playing through vdj, if not might be worth considering...
geposted Mon 29 Aug 11 @ 10:37 am
If you are using an external mixer setup, then the sample output will be lower because the sample output is shared across the two channels. To play at full volume, bring up the other slider (This also gives you some hardware control over the sample volume), e.g: If the left deck is playing out live, bring up the fader on the mixer for the right deck when you play your sample (Make sure that right deck is not actually playing though!)
geposted Mon 29 Aug 11 @ 12:10 pm
