Ok, registering might not be the correct term, and maybe this should be in hardware, not sure ... anyway .....
I use VDJ with both an Xponent and with the Denon MC-6000
When I start everything up, I must go to every knob and slider and move them all through their full ranges so the software will know their positions. Is there some simpler way to do this that I'm missing?
geposted Tue 30 Aug 11 @ 6:53 pm
If both are controlling the same decks then will get this with some controls such as the pitch sliders, volume sliders, etc. where 'soft takeover' is applied to avoid a sudden change in pitch, volume, etc. that would occur otherwise as a result of the mismatch.
Please see https://virtualdj.com/wiki/Pitch%20slider,%20volume%20slider%20or%20gain%20knob%20does%20not%20respond.html
geposted Wed 31 Aug 11 @ 8:06 am
