How the software decides in smart mode if it will be tempo or fade or cut ? can i control it ? and what the "auto-cross length" in options does ? Thanks in advance.
geposted Tue 30 Aug 11 @ 8:26 pm
If it is mixing two songs that have the stars by the bpm it will smart mix (beat mix). Also to the other question you asked, it’s the time it takes to make that mix. So if you move it all the way down it would be like more of a cut than a mix as such. You can pick what kind of mix you want automix to do in the outomix options in the browser.
Hope this helps
Hope this helps
geposted Wed 31 Aug 11 @ 2:30 am
