Hello fellas!
I hope to get some help from you, because now I think I tried allmost everything and I still cant get my DJM-350 to respond in VDJ.
Okay, so this is how it's all hooked up.
My to CDJ-350's are hooked up to the DJM as they are when I'm using them with CD's (I suppose that's also how they should be connected when using the system as a controller?)
Then I have 2 USB cables from the CDJ's to my laptop.
But whyn launching Virtual DJ the CDJ's are responding as they should premapped with all buttons working beautifully, but none of the mixers functions is working :S
What have I done wrong?
http://imageshack.us/photo/my-images/856/screencapk.jpg/
(How my soundoptions is hooked up)
geposted Wed 31 Aug 11 @ 5:52 pm
What version of VDJ are you using, as If it is home free you cant use controllers! Also the mixer is not a midi mixer
geposted Thu 01 Sep 11 @ 5:47 am
hi
i couldn't get on with the asio drivers .i use the two sound card option instead from the same drop down menu .once you have done that select pioneer cdj 350 1 and pioneer cdj350 2 from the sound card menu to the right. hit APPLy button.
now you have two sound cards selected go to the mappers menu open the mappers option button to select the pioneer cdj you want to control the left deck then the right deck independently if you dont they will keep showing the same track in each player.
geposted Fri 02 Sep 11 @ 2:53 pm
