Good Day Everyone. I have recently purchased a Numark DJ IO
It took me some time to get it even to produce sound.
At first it was problems with 64bit Windows 7. I had to try different modes an so on an so forth. Eventually it worked
just using admin installation.
The sound is outstanding But at times for no reason what so ever its stops working. It gives off a digital noise an it freezes
the virtual dj. As if it was pausing a few times a second.
I am using the latest drivers for 64bit. 2.9.13
I've tried different cables an so on an so fourth.
Any advise?
Any advise?
geposted Thu 01 Sep 11 @ 5:21 pm
im having the very same problem.... a serious bit of kit as regards to sound quality, but keep getting random shut downs. the music stops completely, even on virtual dj and a clicking noise comes from the speakers.... virtual dj completely freezes up... did you get the problem sorted??
geposted Sat 10 Mar 12 @ 1:28 pm
I have the sama probleme with windows 7 32 bit.
Perhalps that works and somewhere the become metalic and discontinued.
If I disconnect the USB and reconnect the sound is go but not for a long time.
Any idee.
Any idee.
geposted Mon 28 May 12 @ 11:49 am
SAME HERE! but I get it when using my behringer as soundcard for timecoded turntables
geposted Tue 10 Jul 12 @ 7:35 am
How are you using timecode with a limited edition of VDJ?
geposted Wed 11 Jul 12 @ 6:04 am
