Hi
I would like to know if there's someway to map the hot cues 1,2,3. left and right for total of 6 hot cue buttons.
And I got the estax typhoon i activated the 20 day trial, anyway since I'll keep using the software I purchased the license but i dunno how to activate it, is there someway i can activate it without uninstalling or losing all my cue points and mapping?
thanks for yor help
thanks for yor help
geposted Thu 01 Sep 11 @ 10:52 pm
go to my documents --> virtual dj, copy database.xml, put it somewhere safe..
then uninstall your LE Version and reinstall Virtual Dj Pro, paste the database in the virtual dj folder and all your information and cues will be accessable in Pro..
to map the hot cues, just use
hot_cue 1
hot_cue 2
hot_cue 3
You can just do it for one side of the controller & it will automattically assign to the appropriote deck
hot_cue 1
hot_cue 2
hot_cue 3
geposted Thu 01 Sep 11 @ 11:47 pm
Thank you very much
but how do i stablish it to be to a certain deck you kno so it quickly goes to the second or the first one, also I got an MPD18 midi controller which has 3 banks, how can i map the other 2 banks? so when i switch between maps in the controller VDJ goes to the assigned mapped buttons?
geposted Fri 02 Sep 11 @ 12:00 am
Also what else do I have to copy to keep the Vestax typhoon skin and all the native mapping that came with my LE version of VDJ (you kno the one included with my vestax typhoon)
geposted Fri 02 Sep 11 @ 12:02 am
I don't think you can keep the skin or the mapping... but maybe one of these will do https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=all&search=vestax
for mapping the cues for the mpd you need to assign the decks using
deck 1 hot_cue 1
deck 2 hot_cue 1
you don't need deck assignments for the typhoon, that's built into the definition file
deck 1 hot_cue 1
deck 2 hot_cue 1
geposted Fri 02 Sep 11 @ 1:56 am
I know.
I'm gonna assign them to MPD18
By the was anyclue on how to map each different bank from the MPD18?
thanks
thanks
geposted Fri 02 Sep 11 @ 2:00 am
I have a mpd 24, for that I just change the bank on the device (it's built into the hardware) then It changes the midi note for the pad. If yours does that just use key learn in the simple midi wrapper.
If not you will need to make a shift to work internally in vdj, If you need that I can help but don't think you will...
geposted Fri 02 Sep 11 @ 4:40 am
You will find the Vestax Typhoon LE skin in your VirtualDJ folder -> Skins
Simply make a backup copy of it (It's a ZIP file) and you can restore it again in future by simply copying it back to the Skins folder again.
You should also backup your database and music collection on a regular basis: https://virtualdj.com/wiki/Backup%20Database.html
geposted Fri 02 Sep 11 @ 6:20 am
