Forum: Old versions
Topic: having issues with headphones vdj and hercules rmx console
i have my pc set up with vdjpro 7, have hercules rmx connected via usb, outpues 1&2 on the back of it are going to speakers. that works fine, but when i plug my headphones in i can only hear 1 track at a time (only comes out of left headphone) but is there a way to get it to come out as if i was plugged directly into my computer? (ie master on left, preview on right) through the hercules rmx?
sound setup:
inputs: none
outpues: headphones (master: left chan/headphones right chan)
soundcard: hercules rmx
edit: just tried again, changed nothing, but both songs are coming out of the left headphone only...
geposted Fri 02 Sep 11 @ 3:46 pm
Your sound setup is incorrect. It appears that you have configured it for the mono separated option, which is incorrect for Hercules RMX.
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest v7.0.5 version from https://virtualdj.com/download/updates.html - You can upgrade from Hercules RMX Console Edition at a considerable discount by going to https://virtualdj.com/buy/
Install the latest Hercules firmware and drivers from https://virtualdj.com/wiki/Common_Device_Drivers.html
Check that your RMX is configured correctly: https://virtualdj.com/wiki/RMX.html
