Hi VDJ, I am testing your software against a few others to determine which to purchase. Currently, I have a MacBookPro running Lion and 2 DN-3700's connected to a Pioneer DJM-3000 mixer(not midi). I followed multiple discussions about how to setup the decks, both are running the latest firmware from Denon v2020, both are set to Midi CH1 and Deck All, basically factory default settings for all presets. I started the Mixer, then the right deck, then the left deck, put them into Midi mode, connected, started VDJ and then, I can't quite get the setup correct. I can assign the decks to the proper location in the software so that deck 1 in the SW is my left deck and it displays properly. Same with the right deck on side 2. Now, the problem is that I can't assign the output of deck 1 to run through the deck 1 controller and output to the Mixer while deck 2 is setup to run out through the right controller. I can either have both decks play through 1 of the midi controllers, or I get fatal CoreAudio errors when assigning deck 1 to my left S3500 and deck 2 to my right S3700. I have switched this around multiple times, tested the decks individually, no problems Only when Deck 1 -> left and Deck 2 -> right. Of course, if I can't get this setup, I will purchase something else. If you can help me, VDJ is my front-runner so far.
Please help.
Thanks,
Darren
Please help.
Thanks,
Darren
geposted Mon 05 Sep 11 @ 2:34 am
Hi, This is DJ Kazi, if you email me at javedkazi1@hotmail.com, I will email you back with my number and I can walk you through setting it up. I am using 2 DNs-3700 with Pioneer DJ-800 and SL3 box and loving it
geposted Wed 14 Sep 11 @ 9:52 am
