Forum: Old versions
Topic: Loading pause on decks
I was wondering is anyone experiencing the same issue I'm having when loading a song on the opposit deck that's not playing? what I'm noticing is, while a song is playing on one of the decks and I load a song on the other deck there is a slight pause in the deck wheel rotation before it loads. The song playing is not interrupted it just bothers me, making wonder will the deck playing stop while people are on the dance floor. Is anyone else noticing this issue.. is there and adjustment I can make.. my Denon Cd players are in midi mode.. What should I do.
geposted Mon 05 Sep 11 @ 2:42 pm
This could happen if the tune is not analyzed.
It should not create a problem other than maybe
slower loading.
It's normal for the user interface to momentarily pause when you load a song (While it's busy trying to access the disk.)
This should not have any effect on the playing song and/or video, unless there are performance issues with your computer (Please see https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html )
If you get a long pause (More than 1 second), then this may be due to an external hard disk going to 'sleep' (So VDJ has to wait for it wake and spin back up to normal speed before it can continue loading the song.)
