only my left some times is last a lil bit but sumtimes i just cant get it to work.. what can i do someone please i use maya44 usb
geposted Tue 06 Sep 11 @ 10:40 pm
Check the right/left plugs are the right way round, and that the cartridge is wired to the headshell correctly. Try swapping the carts over and see if the problem swaps sides!
geposted Wed 07 Sep 11 @ 12:38 pm
what do you mean wrap the carts
geposted Wed 07 Sep 11 @ 10:32 pm
I mean swap them. Unscrew them from the tonearms and put the right one on the left deck, and the left one on the right deck. See if the problem swaps sides or not. Just trying to narrow down what the problem may be! Also try swapping the entire deck over - tests like this will help show you where the problem lies, if after all this it's still the left deck in vdj that's playing up, you know by now that it's definately not a problem with your turntables, and must be something to do with your soundcard or timecode settings.
geposted Thu 08 Sep 11 @ 3:07 am
i try that before ! it didnt help! but what i did on Wednesday i change my set up now the left turntable is where the right use to be. it work perfectly wile i was practicing hope it dose int do it again ! thanks for your help if any more help can i contact you?
geposted Thu 08 Sep 11 @ 3:41 am
Sounds like you got bad wires..........if you moved the whole turntable and it fixed itself yet swapping the needles did nothing, its problay caused you were moving the wires and unkinked the bad spot it.
Just my 2 cents
Huey
Just my 2 cents
Huey
geposted Thu 08 Sep 11 @ 6:50 am
what dose Huey Lewis as to do with dizz jahahahah! LOL THANKS ANYWAYS BEATBREAKER
geposted Thu 08 Sep 11 @ 3:38 pm
