Am I doing something wrong? Selected dis-engage beatlock ON-LOAD in options. When I'm playing deck1, I load a song and beatlock in deck 2, then fade over to deck 2. Then I go back to deck1. But when I throw another song into deck2 (with different BPM), the beatlock does not disengage. Is this a bug?
geposted Wed 07 Sep 11 @ 8:43 pm
only thing u need is pitch matchin put it to smart option ignore the disengage beatlock set as off
geposted Mon 26 Dec 11 @ 6:06 pm
That is not a bug. You have selected "disengage beatlock - on load" but you did not disabled the "Auto Pitch Matching" in the config option, that is why if you throw any song with different bpm in any of the deck 1 & 2 VDJ will set the bpm automatically the same. So try to disable the "auto pitch matching" and you will get it the original bpm of each songs right when loaded.
geposted Tue 27 Dec 11 @ 4:06 am
