Forum: VirtualDJ Skins
Topic: Pioneer DDJ-S1 - Page: 1
Hi team,
is there anyone who is working on a Pioneer DDJ-S1 skin?
That will be gr8
Thanks
HF
geposted Thu 08 Sep 11 @ 3:57 am
HI DJ_ro
thanks for the info.
Will keep my eyes open in the controller section...
T
Housefroind wrote :
HI DJ_ro
T
wait bro... It'll be amazing..
I hope the release two months ago will be that someone will review it ... Thanks
Again Loaded.. i hope that the review this time.. Greetings ...
Let us hope. Hopefully cstoll can review it
Please remove the Traktor logo from the skin and it will be approved soon.
Done..
Skin is now available
download link
https://virtualdj.com/addons/13710/Pionner_Ddjt1_full.html
A few comments.
Please write a short description in English too.
Cue buttons on mixer should be pfl instead of cue
Somehow user must know what FX is active. A textzone maybe ?
Use the modify (update) button. Do not submit skin again if you intend to update it.
Tankns DJDAD..... I will update the skin with yours suggestons soon...
Congratulations. Bro This is available now....
djpv_85, congrat on a beautiful skin man. Every now and then I will try a skin from all those great skinners from Virtual DJ. I am very particular about skin even when I have no clue how to make them. lol
djpv_85, you did a number on this skin. The graphics and colors are simple and simply beautiful. You actually have separate wave form for the separate decks which I will actually use. Now with my programmed beat grids of my music library I once again mix mostly by ears, but I still like that skin.
I resized the skin and modified the browser for Mac also. I like It even more. lol
This DDJ-S1, is simply amazing. It even gives me the impression that Virtual DJ sounds better. lol
This is only 4 decks skin with two decks showing at any given time that I am actually using, before If the 4 decks are not laid out I would not use those skins but not this one.
This skin actually inspire me. I have a question. What is the name of that filter effect that you directly have on the skin? I can' t seem to figure out the real name of this filter which i would love to know the name in order to mapp it out to my controllers.
This is work of art in my humble opinion.
dydy1, the filter effect is the built in "filter" of VirtualDJ.
You can assign a knob to "filter" in the mapper settings of VirtualDJ ;)
Jeremie, can you write me a simple script to assign it to one button or a knob?
to assign to a knob:
filter
To assign to a button, this cannot really be done as a filter is generally used from 0 to maximum or 0 to minimum.
Thank you JeremK for the infos. I am now able to assign a knob to the internal filter but Virtual DJ staff have to give more control of that internal filter like able to reset it to default setting with a script. If the skin does not have that filter option It is hard to tell after using it where the middle is at 50 %.
djpv_85, I would not mind to have an option in update of that skin for video mixing where you can just click and change the mixer panel to video mixer panel.
Add a reset button, that's what I've done on my skins. Its 'filter 50%'. Not a fan of skins that look like controllers but nice job.
Good Day
Huey
SNEAK PEAK pioneer ddj-s1 controller virtual dj skin
Is there even Native support or a MIDI mapper for this controller? I have the DDJ-S1 with no luck working with Virtual DJ....can someone please post pix of the settings they use??
Name: Pionner Ddjt1 full
Author: djpv_85 - Limited edition user -
Your current licenses do not allow you to download Skins :(
what can i do????
83%
