Hi Folks
I am now starting to use VDJ all the time as i have taken away the drawer unit from my Pionner MEP7000 and now just using the Pioneer SEP C1 to control OODJ laptop.
I have some great playlists in itunes/on ipod and would love to figure out how to make this work with VDJ. Itunes is stored on my main home computer so the question is how to get the info from this to VDJ on the gig machine. I never put my gig machine online.
If someone could give me a simple step by step guid on how to this it would be great.
Have asked this question before but didnt get an answer.
cheers
Iain
cheers
Iain
geposted Fri 09 Sep 11 @ 4:24 pm
Anyone got words of wisdom on this one ?
geposted Sun 11 Sep 11 @ 10:31 am
Your gonna have to put iTunes on the laptop and once that's done your gonna have to either back up/ burn the playlist on cd's or external hard drives what ever you have that can trransfer data then up load it to your iTunes account on the laptop. If you plug your iPod in one of the task bar buttons should ask you if you want this computer to be an authorize system which apple gives you up to 5 computers to use. But that doesn't mean that you can use mine and take my music it's just letting the system know that you trust this computer to download or whatever you want to do to YOUR DEVICE ONLY!!!
As far as gig system you thru me off line I'm still a newbi but that's how I did it when I switched over from pc to Mac..
geposted Mon 12 Sep 11 @ 3:04 am
All you need to do is copy your iTunes folder from your desktop into My Music Folder in your rig and install iTunes, once done you'll be able to navigate to iTunes folder open your playlist and use within VDJ...
Good Luck,
Joey.....
Good Luck,
Joey.....
geposted Mon 12 Sep 11 @ 9:45 am
Cheers guys. sorry for the delay in my reply. have been away with work all week.
I will give this a bash tomorrow.
Iain
Iain
geposted Fri 16 Sep 11 @ 2:47 pm
