Hello all
I'm currently using the free version of Virtual DJ and I'm just wondring if I buy Basic Pro will that stop the 10 minute limit for my mic?
I'm using a USB mic and I have to use ASIO4ALL for it to connect with VDJ and was wondering if i get Basic Pro would it work, as I don't need the full pro version.
The reason I go through ASIO4ALL is so that I can stereomix and talk at the same time and it works but the 10 minute limit isn't enogh :-P
Thanks in advance
Will
Thanks in advance
Will
geposted Fri 09 Sep 11 @ 7:55 pm
Yes. Look here for a comparision of the software.
geposted Fri 09 Sep 11 @ 8:14 pm
VirtualDJ Basic Pro version has the all the available sound setup options, just like Pro Full version. In other words, you may use multiple sound cards as well as multiple outputs and inputs.
geposted Fri 09 Sep 11 @ 10:17 pm
