guys have two seperate 2tb hardrives with videos.ive been updating them both but is there a way to add the two xmls together for my back up hd.
also want to try keep a copy of them both after they are added together.
cheers
cheers
geposted Mon 12 Sep 11 @ 5:25 am
If the drives have the same Drive Letters:
1. First just backup the 2 XML file
2. Open up a XML file with any text editor and copy the entire content (except Header/Footer)
3. Open the 2nd XML and paste the content at the end before </VirtualDJ_Database>.
4. Saved it as a NEW XML FILE
from CMD Prompt:
Copy 1.xml+2.xml NEW.XML
edit NEW.XML
search and delete duplicated HEADER/FOOTER
If drive letters are different
You need the change it to the right drive letter (use search/replace)
whatever you do, make sure you copy XML files first and use those copy the merge. LEave originals alone.
When all done, make sure the NEW.XML is named VirtualDJ Local Database v6.xml and copy that to the root f the drive.
from CMD Prompt:
edit NEW.XML
geposted Mon 12 Sep 11 @ 6:50 am
from CMD Prompt:
edit NEW.XML
this is where you lost me friend.i have some work left to do (as ive broken spine at the mo so time to ug hds) to update files ect.
edit NEW.XML
geposted Wed 14 Sep 11 @ 8:31 am
sorry staffy. I predict a fast recovery for you.
If you want, you can e-mail the 2 xml files and let me know the Drive Letter to which you gonna use the NEW database in.
I'll edit it for you. It takes less than 1 min.
geposted Wed 14 Sep 11 @ 9:01 am
cheers mate i will do that when im finished updating.
dont get the whole drive letter bit...does this not change when you plug hd into different ports on laptop ect.
geposted Sun 18 Sep 11 @ 3:29 pm
For external hard drives (VirtualDJ Local Database v6.xml), the drive letter doesn't matter - It's ignored. Only the full path and file name need to be correct.
For the internal database for songs on the internal drive (My Documents\VirtualDJ\VirtualDJ Database v6.xml), the full path (Drive, path and file name) must correct.
geposted Mon 19 Sep 11 @ 7:57 am
magic sent you pm cheers
geposted Fri 23 Sep 11 @ 6:55 am
guys is this all i need to do to verge two xml files.(on backup external hds0
geposted Tue 27 Sep 11 @ 7:03 am
jsut log back in today.
I'll check the XML files for you.
Let me know the DRIVE letter it's going to be.
*edit*
jsut check my PM's and replyied with an e-mail addy.
I will get back you by tomorrow afternoon/night.
*edit*
geposted Tue 27 Sep 11 @ 4:26 pm
