Hi guys i have just got a mixtrack pro today.
Now what my problem is is that i am in the uk and have the european model which does not have the hot cues along the top.
Mine has eq kills instead which does not kill eqs it still does the hot cues.
What i want to know is how can i map them to match my controller.
I have already tried key learn then enter "deck 1 eq_kill_low" etc but it does not fuction properly as it will light up both buttons on the controller and also if i press the eq kill bass on deck 2 it will still kill the low on deck one.
Any help would be very much appreciated.
geposted Sat 17 Sep 11 @ 12:24 pm
U don’t have a mixtrack pro, u have a mixtrack ;)
Difference:
Mixtrack pro has an build in sound cart and silver buttons
Mixtrack has no soundcart and has black buttons.
I looked at the picture of the mixtrack and compared it with my pro,
And saw that the mixtrack has got the eq kill’s on top.
Maybe thats your problem, you are using the wrong mappings ?
Difference:
geposted Sat 17 Sep 11 @ 3:29 pm
You need to map the buttons without using deck x in front of the actions.
For example..
eq_kill_low
You dont need to map both sides. If you map the left side using actions without deck x right side will be mapped as well.
For example..
eq_kill_low
geposted Sat 17 Sep 11 @ 4:53 pm
Cheers djdad that sorted it straight away. I new it would be simple just needed pointing in the right direction.
My controller says mixtrack pro along the top and it also has the built in sound so this is defo the mixtrack pro.
I have spoken to a couple of dj shops here in the uk and they all say the same.
The model i got is a traktor le edition model with all kill eqs along the top and that is what numark is now shipping in europe.
I remember them doing this with the total control aswell
geposted Sun 18 Sep 11 @ 5:21 am
ok, i stand corrected another version available aparantly....
geposted Sun 18 Sep 11 @ 6:01 am
Here is the link for the one i got.
Check it out for yourself if you dont believe me.
http://www.chemical-records.co.uk/sc/servlet/Info?Track=MIXTRACKPRO
geposted Sun 18 Sep 11 @ 7:23 am
will the MIXTRACK PRO work with the Pro Full version and mix music videos
geposted Mon 19 Sep 11 @ 5:56 pm
Yes the it is natively supported, you should have no troubles unless your machine can't handle videos well.
Huey
Huey
geposted Mon 19 Sep 11 @ 10:29 pm
