Forum: Old versions
Topic: Vestax Typhoon Deck B not responding
Hi everyone,
I recently purchased the Vestax Typhoon which comes with Virtual DJ 7 LE. Everything was working fine, but now, for some reason, Deck B doesn't recognize that I'm holding the "vinyl"/scratching.
Should I reinstall the ASIO drivers and VDJ? Or is there something else going on.
Has anyone else encountered this problem?
Thanks for any help!
geposted Sat 17 Sep 11 @ 4:48 pm
You have probably toggled vinyl mode off on deck 2.
If you are using the 20 day Pro trial, go to CONFIG -> Options and make sure that Jog Mode is set to Vinyl.
If the trial has expired, you can use Home FREE to do this https://virtualdj.com/download/free.html - You will need to exit before the 10 minute trial of Pro features is up.
That worked perfectly!
Another question, does it make a difference what I have the disc size set to? I know normal vinyl is 33 rpm, but mine is set to 45 rpm. Would changing that create more of a vinyl feel?
Thanks again!
Actually, could I change the setting to my liking in VDJ Home Edition and them show up while using the LE?
