Hi Guy's, Can anybody tell me if it is possible to play a track cued in say deck 1 by hitting an assigned hot key like F1 or whatever and the same for deck two three and four if need be. Also is there an automation feature in the Home version of Virtual DJ which can be used to play music back to back during say a trip to the bar etc,if so where can I find the setting. Your help would be greatly appreciated. Tony.
geposted Mon 19 Sep 11 @ 12:23 pm
Yes, you can map keyboard shortcuts to do this, e.g:
deck 1 play
deck 2 play
deck 3 play
deck 4 play
Please see https://virtualdj.com/wiki/How%20do%20I%20map%20a%20keyboard%20shortcut.html
You can use the automix feature to automatically play music from a playlist - Please see the section entitled PLAYLIST & AUTOMIX in the user manual for VirtualDJ: https://virtualdj.com/wiki/PDFManuals.html
NOTE: VirtualDJ Home FREE is for non-commercial use only and cannot be used at gigs where you are being paid. For paid gigs, you will need to purchase VirtualDJ: https://virtualdj.com/products/comparison.html
deck 1 play
deck 2 play
deck 3 play
deck 4 play
geposted Tue 20 Sep 11 @ 12:29 pm
Many thanks for your kind help,I will give this a try,Tony.
geposted Tue 20 Sep 11 @ 5:17 pm
