Just got my VMS4 and i'm running VDJ LE everything works well... except for my crossfader, regardless of where the crossfader is both songs play through my speakers. Also with VDJ LE am i not able to cue my songs in my headphones, all i can do is here the song that is playing. Any insight on this would be very helpful, thanks!
geposted Mon 19 Sep 11 @ 6:51 pm
Do you have the wallpower adapter plugged in? In some instances it can effect the headphones and also brightens up the lights. Also, there is a knob on the front of the console that says "cue" and " "mstr" or prgrm or something like that. It will let you select what you want to hear in your headphones. Hope that helps.
geposted Tue 20 Sep 11 @ 8:18 pm
on the front ot your VMS there are 2 knobs called assign. If they are bout set to of the crossfader is of. you need to select the channels for what side of the crossfader controlls each deck.
geposted Wed 21 Sep 11 @ 4:36 am
If you just purchased this, I may suggest that you return it.
The new version is just about out and is much better.
If you need details, I will give you details.
Scott
Scott
geposted Wed 21 Sep 11 @ 8:08 am
thanks guys i figured out the problem.
Scott can you send me the details?
Thanks!
Thanks!
geposted Wed 21 Sep 11 @ 2:31 pm
