Hi I'm really new at this and just bought a VMS4 to start mixing. I am having a little trouble mapping my VMS4 and was wondering to seperatley map the levels for the left as well as right side using the ch1 and ch4 sliders. It will only allow me to control the levels for the deck being played and not for both. If someone could help me out with the script that i would need to input that'd be great...thanks.
geposted Tue 20 Sep 11 @ 6:58 pm
you just need to map one side of the controller and it will do the other automatically... also the mixer is not midi, only the decks so the faders are impossible to map. the vms 4 is natively supported in the current version, or if you register a full pro license you can download djdads mapper
geposted Tue 20 Sep 11 @ 7:06 pm
That explains why adjusting the fader levels on the VMS4 does not change the position on the software display. I just picked one up, does the full version change that, or is there just no feedback at all?
geposted Sun 02 Oct 11 @ 11:21 am
