Good day, hope all is well. After days of reading all kind of info etc, I think I finally solved my problem. The reason I am seeking help is to see if there is something I can about my new issue. Please keep it simple as I am not much of a PC buff. Here goes.
Per LatencyMon, the reason I was getting audi glitches was because of NVIDIA driver. It was reading at 7 point something and I understand that it should read under 1. So I disabled NVIDIA and the gliches, which happened intermittently, were gone.
My issue is now my screen resolution can only be 1024x768 or 800x600. Using 1024x768 and the same 1024x768 for the skin. It just does not look as good as 1280x768. Is there anyway I can use 1280x768 and have it work properly? Had my MC6K since about Feb/11 and I just noticed this issue in Aug/11. Everything is up to date. Did all the recommended optimizations as well.
Using XPS L501X.
Windows 7.
Intel core i7.
VDJ pro
Any help would be greatly appreciated. Thanks in advance.
Using XPS L501X.
Windows 7.
Intel core i7.
VDJ pro
geposted Tue 20 Sep 11 @ 11:46 pm
