im going to buy the djm 350, is ther a mapper i need to download for this mixer. if so, can u link me up coz i cant find it.
thanks, panos.
thanks, panos.
geposted Wed 21 Sep 11 @ 9:21 am
mixers are better left as the audio mixer only, but if you have to have the on screen mixer move with you, just map fake everything, as there is no point bypassing pioneers expensive electronic circuitry for vdj's sub standard eq's, and the very minor but real lag time associated with midi controllers.
forgot to say that no on has created a definiion file yet, but without needing to conrtol leds you could just use simple midi to map it with "key learn" then type the command in the action box.
fake_crossfader : move the crossfader on the skin without changing the sound.
fake_level : move the volume fader on the skin without changing the sound.
fake_eq_high : move the equalizer on the skin without changing the sound.
fake_eq_mid : move the equalizer on the skin without changing the sound.
fake_eq_low : move the equalizer on the skin without changing the sound
If you want to record or broadcast you should use another sound input and set up "record loopback" in advanced config.
geposted Wed 21 Sep 11 @ 9:32 am
I dont think the djm 350 is a midi mixer as I cannot find any where on the internet that has it listed as a midi mixer.
geposted Wed 21 Sep 11 @ 10:02 am
looks like ian is right... maybe you should get a djm 400 instead.
geposted Wed 21 Sep 11 @ 10:25 am
