kam digi one or hercules m2 mp3,whats the better one to go for and why?
these are both in my price range,so could do with advice before i bid
thanks
thanks
geposted Thu 22 Sep 11 @ 12:05 pm
Have you personally used either one?
If not, I would try to find someone or a shop or something so you can get your hands on one before you buy. The options are SO diverse when it comes to controlling music that the best advice is try before you buy. What works for the guy down the street might not work for you. How much money is too much for you to figure out if a piece of gear is right for you?
You could pick one based on someones opinion here then when you get it, you realize it isn't quite what you expected?
Will there be a small part of you that wonders why you got bad advice?
geposted Thu 22 Sep 11 @ 12:26 pm
honest good advice,thanks,but its only for home use,the odd party at home,but more for me,as i love my music
geposted Thu 22 Sep 11 @ 12:58 pm
Hi,
I have a Kam Digi One and the latest Virtual Dj software.
My problem is that I cannot hear both songs in my headphones, as the putton "PFL" is active for only one song & not for both.
I know other consoles have a special thing so that they can shift from hearing both songs in the headphones or only one. But Kam Digi One doesn't have it and neither the software!
This is my config:
Input: none
Output: headphones
Sound card: ME100
I would be so happy if someone could help me!
This is my config:
Input: none
Output: headphones
Sound card: ME100
geposted Tue 17 Jan 12 @ 5:11 pm
Okay, try this and see if it will work for you, it has worked for me and for others with similar problems..
The problem is the Hercules dj console 4-Mix, in order for your headphones to work you need to setup in advance sound cofig settins as follows.
1. In the 4-Mix taskbar icon, right click and set the "Audio Mode" to "WDM".
2. Click on the "Advanced" tab set "Headphone Channels" to 1-2, once done click out.
2. Go into advance sound card config in VDJ and add "Headphone" line in the dialog.
3. Add your "Herciles DJ console 4-mix" as the sound card.
4. Add output 1&2 for your headphone channels in your console.
5. If you are Using Both "Master output" and "Headphone output" to the 4-Mix Console, Then you could use ASIO drivers and 3&4 outputs for headphones.
Good Luck,
Joey....
Good Luck,
Joey....
geposted Tue 17 Jan 12 @ 8:25 pm
Two deck controllers by default only allow one deck to be pre-listened to at the same time.
Please see the following FAQ page:
https://virtualdj.com/wiki/Pre-listening%20to%20multiple%20decks.html
geposted Wed 18 Jan 12 @ 5:13 am
