Hi,
I removed a song from iTunes but it will not leave Virtual DJ. I have done the check clean fix thing and it looks like it would work as it says there is 1 file that doesn't exist anymore but when I browse my music it is still there.
Thanks,
DJ Hypernate.
Thanks,
DJ Hypernate.
geposted Thu 22 Sep 11 @ 2:55 pm
I thought I had checked this already but the problem was the song was still left in iTunes even though the file no longer existed. After removing it from iTunes it fixed the problem.
geposted Fri 23 Sep 11 @ 8:53 pm
do the check, clean and fix to ur database, see if that helps
geposted Sun 16 Oct 11 @ 6:56 pm
