When I tried to load VDJ I get (Error in the video drivers)...How do I fix this??? Thanks for your help!
geposted Fri 23 Sep 11 @ 5:30 am
I'm guessing here....
Reload or update your video drivers?
geposted Fri 23 Sep 11 @ 6:24 am
how do I do that??
geposted Fri 23 Sep 11 @ 6:37 am
It will remember your last session, sounds like your not currently connected to a screen/projecter just hit ok
Go to config > video > activate > select > window > if connected to outside source select your video card from drop down box.
Remember to connect equipment up before booting up.
geposted Fri 23 Sep 11 @ 6:39 am
This will not let me load VDJ at all
geposted Fri 23 Sep 11 @ 7:15 am
What setup were you using, the last time you ran VDJ and it was OK?
If you had a second screen connected, or you were using a different video/graphics configuration, then you need
to set it up the same way this time.
geposted Fri 23 Sep 11 @ 7:44 am
I did a re-Boot of the system...and it now works....I don't know what was wrong...
geposted Fri 23 Sep 11 @ 8:17 am
Thanks for all your help!!!!
geposted Fri 23 Sep 11 @ 8:18 am
