On VDJ optons > jog mode, it says in the manual,
"Jog Mode – adjusts the default mode for interfacing with a controller‘s jogwheel – Vinyl or CD modes"
So in my case I use the HC4500 and have it set on CD but what is the different between Vinyl and CD modes ad where should I have it set?
Many thanks!
Cheers,
P.
Many thanks!
Cheers,
P.
geposted Fri 23 Sep 11 @ 4:20 pm
On the HC4500, press the JOG MODE button to cycle between CD, vinyl and search modes.
In vinyl mode, the jogwheel stop and scratch the music when you press down in it. It will pitch bend otherwise.
In CD mode, it will always pitch bend (This is the best setting if you don't scratch.)
NOTE: Changing the Jog Mode settings in CONFIG -> Options is the same as changing them with the JOG MODE button.
geposted Sat 24 Sep 11 @ 1:38 pm
