Ok, I have been having trouble setting up my config to preview songs through my headphone while other songs are playing. Here is what Im working with. Macbook Pro, American Audio DP2 Controller (which I have connected through USB to my Mac), and an American Audio 4 Channel Mixer. I current have each deck from controller going into each separate line on the mixer. Can someone please tell me the correct config in VD to preview???
geposted Sat 24 Sep 11 @ 9:02 pm
If they are going into two separate channels on your external mixer, then you should connect your headphones to the mixer and pre-listen using the PFL/CUE buttons on the mixer.
Make sure that you have set your sound config in VirtualDJ to: Outputs: External Mixer
Please see https://virtualdj.com/wiki/External%20mixer%20pre-listening%20with%20headphones.html
geposted Mon 26 Sep 11 @ 5:48 am
