Hello,
i am having an issue with my timecode cds. here is my configuration:
VDJ : Free Home FREE v7.0.4
Decks : 2 x Numark Axis 4 Professional
Soundcard : Maya 44 USB (Maya44 USB 64 bit driver for Windows 7 installed)
OS : Windows 7 64bit
Timecodes : CD timecodes from VDJ website (consumer grade level)
you will notice that there is no mixer listed above and that is because i do not have one. i want to use VDJ's internal mixer for now. please dont laugh at this set up, i know its not ideal but i just want to get this problem fixed before i improve my set up and spend more money on a mixer.
and before anyone comments, yes you can use timecodes on the free home version, but only for 10 minutes.
so...in config, i select 'Laptop with USB Soundcard' and then my config settings are:
Inputs : Timecodes
Outputs : Single Output (not really bothered just want to get this issue fixed)
Sound card : ASIO Driver (and then i select Maya44 USBAudio ASIO from the drop down list)
Then i click Timecode Config. the drop down list for timecode type is 'VirtualDJ CD'.
1) the first problem is that both decks say 'quality:0%' - at all times.
2) the second problem is that when i jog/toggle the cds decks forward or backward a little bit, the signal starts up but doesnt stop - it continues as if its playing - and also the lights on the maya 44 soundcard are lit up permanently as if the deck is playing. to get it to stop, i have to press play on the cd decks and then press pause/stop. at all times quality still says 0%.
please, any help appeciated.
Inputs : Timecodes
geposted Mon 26 Sep 11 @ 1:25 pm
