Hey!
I have a little problem with VDJ 7.0.5 Trial. I was not satisfied with the original VDJ skin (no bassfader) so I started to look for some more complex skins with more features. Finally found it, it is "MIX Station SV 03 (V4.0)", the Black one. I found it perfect for my purposes.
Absolutely awesome - even though it is from 2003...
But the real problem is:
in the original VDJ7 skin, there is a great waveform songposition display. The MIX Station SV 03 (V4.0) doesn't have it, it just has some different brightnessed blocks. I liked the waveform solution much better, but I don't know how to implement it to this "old" skin. I tried to edit the XML, put a waveform="yes" at the beginning of the songpos code, and editing the BMP file by coloring the default blocks, but it became a little bit weird and useless, and didn't help at all.
Here it is after "fixing":
http://img607.imageshack.us/img607/8566/weirdm.png
My question is:
how can I make the waveform display mode work in this skin without any visual flaws, just like in default VDJ7?
Thanks for your answers in advance.
Ben
My question is:
Ben
geposted Tue 27 Sep 11 @ 12:33 pm
