I have a hercules rmx, with two time codes and a midi keyboard
and with the keyboard plugged in, the sound slows down sometimes and i'm basically wondering
what do i need to change in my settings to get best audio sound, i don't care if its really high latency
or stuff like that, as i never do any scratching.
when they keyboard is not plugged in, it runs fine, but i guess my controllers are taxing the program pretty hard.
thanks.
thanks.
geposted Tue 27 Sep 11 @ 3:42 pm
You most likely have performance issues with your computer.
Please see https://virtualdj.com/wiki/Performance%20Issues.html
NOTE: The full VirtualDJ Professional is required to use timecode and other MIDI controllers in addition to (Or instead of) the RMX. Assuming that it is not second hand or the discount has not already been used, your RMX DJ Console entitles you to a significant discount off upgrading to the full VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
If you have already purchased VirtualDJ Pro, please register your serial number on the page https://virtualdj.com/users/edit.html and download the latest version from https://virtualdj.com/download/updates.html
geposted Wed 28 Sep 11 @ 7:43 am
