Hey guys,
Just got my Numark MixtrackPRO and Virtual DJ program.
When setting up the audio, I select Numark for the soundcard, and have the output as headphones, and channel 1 & 2 as the master.
I have two speakers with built-in amplifiers hooked directly up to the two RCA inputs located at the back.
When playing around, one of the speakers plays normally the other plays exactly the same as the headphones? Almost as if the RCA inputs are Channel 2&3 or 1&4?
Basically, the headphones are right and play the cue/preview.
One of the RCA inputs plays the master, and the other plays the cue/preview? If i could select each channel for each output it would work, though i can only have Master 1&2 Headphones 3&4 or visa versa?
Any ideas?
Any ideas?
geposted Wed 28 Sep 11 @ 3:03 am
It sounds as though you have selected the mono separated (Y cable option.)
What are your sound settings set to?
Check that they are set as shown on the following page: https://virtualdj.com/wiki/MixTrack%20Pro.html
Also, make sure that you have the latest VirtualDJ LE installed. Register your LE serial number on the page https://virtualdj.com/users/edit.html and then download the most recent version from https://virtualdj.com/download/updates.html
geposted Wed 28 Sep 11 @ 7:09 am
