So I am using a Behringer DJX900usb with virtual DJ pro. The problem I am having is that when I'm trying to mix. The connection I have right now is from My laptop with VDJ to the DJX900USB which is connected to to a 2200 Watt amp which go to 2 speakers. What is happening right now is that both, the left and right tracks, of VDJ are playing on one channel of my mixer, channel 1. I am currently working for a different company that uses scratch live with a Behringer DDM4000 and it works as the left track of the software plays on channel 1 of the mixer and the right track of the software plays on channel 2. I can still return this mixer so if I can't fix this I am going to but I need some help if there is something I can do.
geposted Thu 29 Sep 11 @ 7:51 pm
Look at the text at the top of channel one on your mixer....
You see that it says USB as one of the input options?
Do you see that on any of the other channels?
No, because only one channel of your mixer has a USB audio input.
geposted Fri 30 Sep 11 @ 4:31 am
friend what version of vdj are you using.if its home free version i dont think you can use hardware not sure maybe teamer will join in.
check your sound set up there is a full thread on different set ups in forum
geposted Fri 30 Sep 11 @ 7:55 am
