Pues creo que este controlador merece su propio topico. este fin de semana se sabra todo sobre este nuevo controlador
[youtube]CIgNrC3VhqY&[/youtube]
![](/image/40696/72886/n4_angle_lg.jpg)
![](/image/7136/72887/n4_back_lg.jpg)
•4-Deck controller and DJ Mixer that works with or without the computer
•External mixing (2 CD/Turntable + 2 Mic)
•Built-in professional USB audio interface with balanced XLR outputs
•Large touch-sensitive control wheels
•Serato DJ Intro software included
•4-Deck version of Virtual DJ LE Included
•Mixer section with EQ, loop and effects controls
Four Decks of Control. Are you ready?
Featuring four decks of software control plus a built-in mixer that can be used with or without a computer, N4 is designed for DJs who want powerful capability in a lightweight, portable package. N4 is a complete DJ controller that has everything you need to perform at your highest level: large, touch-sensitive platters, four decks of software control with loop and effects controls, a built-in USB audio interface and a comprehensive mixer section with EQ and gain controls. N4 comes with both Serato DJ Intro software and a 4-deck version of Virtual DJ LE.
Built-In Mixer
N4 is built for flexible control of virtually any music source. You can use its built-in mixer to bring external sources into your mix including turntables, CD players and MP3 players: choose in an instant to switch from controlling 4 decks of software to controlling 2 decks of software plus 2 channels of external source.
Timecode Capability
With the ability to use time code, N4 sets a new standard for 4-channel controllers in its class. In addition to its four decks of MIDI software control, you get the ability to use CD players or turntables to control your advanced DJ software by employing turntables with time-coded vinyl or CD players with time-coded CDs.* Turn N4 into a four-platter controller by adding on two controllers or two turntables like the NDX900 Controller or two TTXUSB turntable.
Essential Elements
Of course, N4 comes equipped with an intuitive layout of faders, knobs and buttons that feel great, provide the right amount of resistance and are built to withstand abuse. Each deck is outfitted with standard DJ tools including a pitch fader with key-lock control, looping controls, and effect and sampling controls. Four Video Fade selectors are also on-board to give you video mixing capability when using Virtual DJ.**
Built-in USB Audio Interface
N4 is Class Compliant: plug it in to your laptop, load the software and you're ready to go. N4 enables USB recording of all your analog and digital sources. Whether you're using four decks or software or combining software and externals sources from N4's mixer section, your entire performance can be recorded, saved and posted to your website or social media. For your live audience, N4 has balanced XLR outputs, giving you a solid, professional connection to virtually any sound system.
Start taking control with N4 from Numark.
*Upgrade to Virtual DJ Pro software is required to use N4 with time-coded vinyl or CDs. **Upgrade to Virtual DJ Pro software is required to output full-screen video.
Built-In Mixer
Timecode Capability
Essential Elements
geposted Fri 30 Sep 11 @ 3:47 am
![](/image/6830/72976/311075_10150397042336085_86785941084_10080662_1788093752_n.jpg)
Aqui otra foto, cada dia me gusta mas.
geposted Sat 01 Oct 11 @ 5:58 am
Buen cacharro, para lo que cuesta y lo que ofrece lo veo muy buena opción, de todas formas cualquier aparato de estos es mejor ver y tocarlo antes de comprar.
geposted Sat 01 Oct 11 @ 7:41 am
Pues este podra ser mi futuro set up,
numark n4
redwave
laptop stand dj pro
todo de casa numark, claro mi steel no la vendo ni loco, me fascinava la n6, pero estando fuera de mi alcance esta es la mejor opcion
numark n4
redwave
laptop stand dj pro
geposted Sat 01 Oct 11 @ 9:02 am
Por cierto alguien sabe cuando saldra?? y cuanto costara?? posiblemente lo actualice por mi vms4..
geposted Wed 05 Oct 11 @ 4:17 pm
Seria la Version Ekonomika de la NS6. Para k HUbiera valido la Pena en verdad hubiera puesto MINIMO entradas USB para tus tokadas komo la Mixdeck. Pero sin el Dock para Ipod ni CD players para k no aumentara precio. Pero depende del Kosto SI VALE 20% Menos k la NS6 mejor junta y kompra NS6 SIN DUDARLO.
geposted Sun 09 Oct 11 @ 7:54 pm
El N4 cuesta 400 eur aprox.
geposted Sun 09 Oct 11 @ 8:07 pm
mmm no me tinca mucho, la encuentro tan plastica como la mixtrack, ademas tienen los mismos botones y perillas de la total control, el plato se ve igual de plastico que la mixtrack. mm hay q verla funcionando.. saludos..
geposted Sun 09 Oct 11 @ 8:22 pm
vi en alguna pagina de Internet que el costo era mas o menos €399 recién fue presentada en el BPM SHOW 2011, y que estaría disponible aproximadamente en Diciembre 2011 a enero 2012. Me parece que es un equipo excelente, mas que ser la "hermana menor" de la MixDeck Express o la NS6, es mas como un Upgrade de la Mixtrack Pro, si el precio es realmente ese, es una buena opción, comparada con las también recién presentadas DDJ- Ergo de Pioneer o la Vestax VCI-400
Tengo que ver los componentes, si es plastico tipo de juguete NO, mas si los materiales son como los de la pioneer ddj ergo por €399 es una compra muy buena sobretodo por su mixer midi/analogico, y todo lo q ofrece, ademas con un buen mapeo puedes hacer maravillas con esta consoll, no queda que esperar hasta que salga la venta, y tocarla con mano, los enviados de vdj italianos, han dicho que lo mejor del bpm en inglaterra, son la vci i400, pioneer ddj ergo, numark n4... En espera!!!!!!!!!!!!
En precios
vestax €999
pioneer €499
numark €399
En precios
vestax €999
pioneer €499
numark €399
geposted Mon 10 Oct 11 @ 5:22 am
pochitodj wrote :
vestax €999
Saludos pochitodj, bueno para hacer una correción nada mas, el precio de la VCI 400 sera de 799 euros, en dos semanas llegara para hacer pruebas al local donde trabaja un amigo, ya les tendre noticias en cuanto yo la pruebe tambien....
![](/image/69033/73656/00020462.gif)
geposted Mon 10 Oct 11 @ 6:12 am
Tienes razon me equivoque era en dolares la vestax, que al cambio odierno sale la cantidad que dices gracias del apunte se me paso por alto, los precios de las otras 2 estan correctos en euros para saber su precio en dolare basta hacer la conversion al cambio del dia
geposted Mon 10 Oct 11 @ 7:27 pm
N4 is the way to go...
geposted Tue 11 Oct 11 @ 6:38 pm
Primera recencion de la N4, se la ve muy bien, cada dia mas seguro de mi futura compra
geposted Sat 07 Jan 12 @ 10:26 am
