Hello everyone, Ever since I have started DJ'ing I have used VirtualDJ, Well I visited Numarks Website This Morning and Saw A Software called Numark Cue. It looked just like VirtualDJ So I tried to use it. When I installed the software and opened it, it asked me for my serial number. I own a Numark Mixdeck and I entered it. Well it said it was unvalid. Is there a reason for that?
geposted Fri 30 Sep 11 @ 8:02 am
Its the same software just with the Numark brand as for you Mixdeck you already registered it here which is what you would regardless.
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 30 Sep 11 @ 8:15 am
Alright man i appreciate it!
geposted Fri 30 Sep 11 @ 8:19 am
Please see https://virtualdj.com/wiki/What%20is%20the%20difference%20between%20VirtualDJ%20and%20Numark%20Cue%20or%20VirtualVinyl.html
Your serial number for VirtualDJ LE for MixDeck is not compatible with Numark Cue, which is full software (Equivalent to the full VirtualDJ Pro.)
If you would like the full software, you can upgrade to the full VirtualDJ Professional at a considerable discount: https://virtualdj.com/buy/
geposted Fri 30 Sep 11 @ 9:18 am
Do you mean the Numark Mixdeck?
geposted Fri 30 Sep 11 @ 9:20 am
Yeah the software that came with it is only compatible with the Mixdeck.
geposted Fri 30 Sep 11 @ 9:22 am
