Forum: Music discussion
Topic: Hide song title while broadcasting using VDJ/Virtual DJ
After searching for the answer here, noticed nobody really answered this question so for those who need:
To hide song title while broadcasting using ONLY VDJ/Virtual DJ is simple:
Open computer registry editor tool (Run > regedit (press enter))
then go to HKEY_CURRENT_USER\Software\VirtualDJ
select string "BroadcastShowTitles" and double-click to edit value. Value should be "0" to hide, "1" to show.
geposted Fri 30 Sep 11 @ 5:15 pm
cool =)
Thanks!
System: MacPro 10.9.4 // How can i hide song titel with my Mac? pls Help!
THIS IS WHAT I FOUND MOST USEFUL....
JUST GO INTO OPTIONS....OPEN IT UP ALL THE WAY......
THEN SCROLL DOWN TO THE BROADCAST TAB.......
THERES A SELECTION LABELED " broadcastsonginfo "....
CHOOSE NO....
POINTMAN BLACKCHAIN... many thanks! - For those who can not find it simply follow POINTMAN BLACKCHAIN's instructions and then search for - broadcastsonginfo - click on NO and save the options by closing the window. simple! Many thanks Pointman!
how can i hide using mac? thru vdj?
Tried this option and it still shows in the video.
turn off the video skin
Hi i dont find the broadcast in vdj 8.0 and i also tried the first and no luck any other way to not broadcast song info? cheers
Just look for broadcastSongInfo in Settings=>options - and set to "no" if you dont want to send titles
For broadcast you might also want to have to look at broadcastSongInfoFormat where you can change what to display
NOT ALL HEROS WEAR CAPES
CHOOSE NO....
