Hello fam. Has anyone mastered the crab scratch with the mix track pro. For some reason, it seems as though the mixtrack pro is not sensitive enough to handle it. I have played with the settings, and still nothing. I cannot find any settting for the cross fader to adjust it's sensitivity. Is this just a drawback with the software or hardware?
Any help on the settings would be greatly appreciated. New at this and trying to learn. Much Mahalo!
T-Rock
T-Rock
geposted Sat 01 Oct 11 @ 2:32 pm
the crossfader is really weak on the mixtrack and not replaceable... I would forget about crab scratching until you get a better controller. I have a reloop jokey 2, it's fader is amazing, but the fastest it will scratch is a 2 click flare, look it up
geposted Sat 01 Oct 11 @ 11:20 pm
No doubt. Good looking out. I was actually looking at getting the Reloop 3, however, I have seen some not so good reviews on the scratching latency. Everything else on the device seems awesome.
geposted Mon 03 Oct 11 @ 4:36 pm
you can fix the scratch latency with the registry tool, huey has a video on his blog of how to do it, the jockey 3 has 3 times the clicks per rotation so that can only mean it's better at scratching than the jockey 2 and i have that set up pretty damn good, im thinking about getting one, but waiting to see if novation do a platter version of twitch, that would be the ultimate controller, apart from the vci-400 imo
geposted Mon 03 Oct 11 @ 4:45 pm
I find scratching pretty useless on most controllers - it all depends how good your laptop is I guess....
geposted Mon 17 Oct 11 @ 12:48 pm
