On a job right now and this happens:
In the middle of a song, the track whent into overdrive as if I hit the fast forward button yet sped through the song in maybe 1 second. Loaded another song and the same thing happened as soon as I hit play. Restarted the program and all is back to normal. No buttons had been pressed. Anyone experience this before?
Setup:
MacBook pro running windows 7 on bootcamp
FireWire HD
Hc4500
Latest version of vdj
Setup:
FireWire HD
Hc4500
geposted Sat 01 Oct 11 @ 7:09 pm
Probably you have the Denon controller on Search mode. If the jog is just between 2 "data points", this could hapen. Vibrations will cause vibrations in the jog and this will fire the "data point". Setting the jog to bend mode will solve the issue, just as pushing thejog a little forward or backward.
geposted Sun 02 Oct 11 @ 11:31 am
