If you have a playlist at the right loaded with songs how do you get the last song or the newly added song to play next. If you're playing live and someone requests a song how do you put it in the song list to play next?
How do I "BPM" all the songs at once?
How do I keep a song in the playlist after it's played?
Is there a way to move the songs up the list, if you want to change the order? For example you what to move song #25 up to position #6.
How do I add my own samples into the "sampler"?
How do you put a song back at the start if you've already started playing the song?
On the net there are VDJ manuals telling you what each "button" can do, but is there a manual that tells you HOW to do each function?
geposted Thu 06 Oct 11 @ 7:54 am
with the songs in the list just drag and drop into position.
with the samples just make them and save in the sampler section.after yous name and save it jus open sampler in vdj and right click then load it will then bring you to your documents....open samples and select desired sample and play away.
geposted Thu 06 Oct 11 @ 7:58 am
Pay for a pro license. The Home Free version DOES NOT allow for public performance, regardless of whether or not you are getting paid.
http://www.amazon.com/DJing-Dummies-Sports-Hobbies/dp/0470663723
http://www.goodreads.com/book/show/1180299.How_To_Be_A_DJ
http://www.goodreads.com/book/show/1781497.How_To_Be_A_DJ
geposted Thu 06 Oct 11 @ 8:04 am
geposted Thu 06 Oct 11 @ 8:07 am
I what to see if the software does what I want it to do before I buy it. I have NO plans to take a "home" version on stage. That is why I want the proper manual. So I take it that there is no step by step manuals, just guides telling what it can do, not how?
geposted Thu 06 Oct 11 @ 7:09 pm
